Argon doc tool fails
It keeps asking if argon is blinking yellow. I make it blink yellow and the doc flashes and reboots but the argon never finishes the setup after that.
I tried serial 28800 and it goes to Particle Cloud Debugging Tool. This is all I can get it to do.
ideas?
Which doc tool are you using? If you haven't tried the Device Doctor, please give it a go and share the logs here. Thanks!
