I am looking for a quick enclosure for my project. I’m using a shield shield, mainly because it gives me a few mount holes, a barrel connector, and voltage translation. Does anyone know whether the power connector and mount holes on the shield shield would line up with an arduino case? If so, is there a particular case you would recommend?
Hi Ocean,
So you would need to look for a Mega 250 case. I just compared the shield shield v2 and it looks like the barrel connector and voltage translation will fit in some cases. However, it does not look like it will have the same mounting holes but this could be fixed quick with a drill. The other consideration is room for the shield so you have to look for a case with room for a shield. I found something that may work here
http://www.sora-shop.com/detail/index/sArticle/169
