Hello,
Thanks for taking the time to lend a hand!
I’m trying to collect data from two different I2C boards on an Electron with up-to-date firmware. I have an MPU6050 on Wire (D0=SDA & D1=SCL), and an BMP085 on Wire1 (C4=SDA & C5=SCL). Independently, each works fine. However, when I combine the code for each it gets hung up in a while loop at line 147 that’s looking at whether Wire1/BMP085 is available or not.
Here:
int readIntRegister(unsigned char r)
unsigned char msb, lsb;
Wire1.beginTransmission(I2C_ADDRESS);
Wire1.write(r);
Wire1.endTransmission();
Wire1.requestFrom(I2C_ADDRESS, 2);
while(!Wire1.available()); // LINE 147 WHERE THE CODE HANGS
msb = Wire1.read();
lsb = Wire1.read();
return (((int)msb<<8) | ((int)lsb));
This code is called in setup(), after the code that sets up Wire/MPU6050 is executed. My I2C addresses are correct at 0x68 for the MPU6050, and 0x77 for the BMP085. No clue what’s going on here, so any hints would be greatly appreciated. The complete body of code is below.
const int MPU_addr=0x68; // I2C address of the MPU-6050
int16_t AcX,AcY,AcZ,Tmp,GyX,GyY,GyZ;
// From the datasheet the BMP module address LSB distinguishes
// between read (1) and write (0) operations, corresponding to
// address 0xEF (read) and 0xEE (write).
// shift the address 1 bit right (0xEF or 0xEE), the Wire library only needs the 7
// most significant bits for the address 0xEF >> 1 = 0x77
// 0xEE >> 1 = 0x77
int I2C_ADDRESS = 0x77; // sensor address
// oversampling setting, 0 = ultra low power, 1 = standard, 2 = high, 3 = ultra high resolution
const unsigned char oversampling_setting = 3; //oversampling for measurement
const unsigned char pressure_conversiontime[4] = {
5, 8, 14, 26 }; // delays for oversampling settings 0, 1, 2 and 3
// sensor registers from the BOSCH BMP085 datasheet
int ac1;
int ac2;
int ac3;
unsigned int ac4;
unsigned int ac5;
unsigned int ac6;
int b1;
int b2;
int mb;
int mc;
int md;
// variables to keep the values
int temperature = 0;
long pressure = 0;
// read temperature and pressure from sensor
void readSensor() {
int ut= readUT();
long up = readUP();
long x1, x2, x3, b3, b5, b6, p;
unsigned long b4, b7;
//calculate true temperature
x1 = ((long)ut - ac6) * ac5 >> 15;
x2 = ((long) mc << 11) / (x1 + md);
b5 = x1 + x2;
temperature = (b5 + 8) >> 4;
//calculate true pressure
b6 = b5 - 4000;
x1 = (b2 * (b6 * b6 >> 12)) >> 11;
x2 = ac2 * b6 >> 11;
x3 = x1 + x2;
b3 = (((int32_t) ac1 * 4 + x3)<<oversampling_setting + 2) >> 2;
x1 = ac3 * b6 >> 13;
x2 = (b1 * (b6 * b6 >> 12)) >> 16;
x3 = ((x1 + x2) + 2) >> 2;
b4 = (ac4 * (uint32_t) (x3 + 32768)) >> 15;
b7 = ((uint32_t) up - b3) * (50000 >> oversampling_setting);
p = b7 < 0x80000000 ? (b7 * 2) / b4 : (b7 / b4) * 2;
x1 = (p >> 8) * (p >> 8);
x1 = (x1 * 3038) >> 16;
x2 = (-7357 * p) >> 16;
pressure = p + ((x1 + x2 + 3791) >> 4);
// read uncompensated temperature value
unsigned int readUT() {
writeRegister(0xf4,0x2e);
delay(5); // the datasheet suggests 4.5 ms
return readIntRegister(0xf6);
// read uncompensated pressure value
long readUP() {
writeRegister(0xf4,0x34+(oversampling_setting<<6));
delay(pressure_conversiontime[oversampling_setting]);
unsigned char msb, lsb, xlsb;
Wire1.write(0xf6); // register to read
Wire1.requestFrom(I2C_ADDRESS, 3); // request three bytes
while(!Wire1.available()); // wait until data available
msb = Wire1.read();
lsb |= Wire1.read();
xlsb |= Wire1.read();
return (((long)msb<<16) | ((long)lsb<<8) | ((long)xlsb)) >>(8-oversampling_setting);
void getCalibrationData() {
Serial.println("Reading Calibration Data");
ac1 = readIntRegister(0xAA);
Serial.print("AC1: ");
Serial.println(ac1,DEC);
ac2 = readIntRegister(0xAC);
Serial.print("AC2: ");
Serial.println(ac2,DEC);
ac3 = readIntRegister(0xAE);
Serial.print("AC3: ");
Serial.println(ac3,DEC);
ac4 = readIntRegister(0xB0);
Serial.print("AC4: ");
Serial.println(ac4,DEC);
ac5 = readIntRegister(0xB2);
Serial.print("AC5: ");
Serial.println(ac5,DEC);
ac6 = readIntRegister(0xB4);
Serial.print("AC6: ");
Serial.println(ac6,DEC);
b1 = readIntRegister(0xB6);
Serial.print("B1: ");
Serial.println(b1,DEC);
b2 = readIntRegister(0xB8);
Serial.print("B2: ");
mb = readIntRegister(0xBA);
Serial.print("MB: ");
Serial.println(mb,DEC);
mc = readIntRegister(0xBC);
Serial.print("MC: ");
Serial.println(mc,DEC);
md = readIntRegister(0xBE);
Serial.print("MD: ");
Serial.println(md,DEC);
void writeRegister(unsigned char r, unsigned char v)
Wire1.write(r);
Wire1.write(v);
// read a 16 bit register
Wire1.write(r); // register to read
Wire1.requestFrom(I2C_ADDRESS, 2); // request two bytes
msb = Wire1.read();
lsb = Wire1.read();
Wire.setSpeed(100000);
Wire.begin();
Wire.beginTransmission(MPU_addr);
Wire.write(0x6B); // PWR_MGMT_1 register
Wire.write(0); // set to zero (wakes up the MPU-6050)
Wire.endTransmission(true
Wire1.setSpeed(100000);
Wire1.begin();
getCalibrationData();
Wire.write(0x3B); // starting with register 0x3B (ACCEL_XOUT_H)
Wire.endTransmission(false);
Wire.requestFrom(MPU_addr,14,true); // request a total of 14 registers
AcX=Wire.read()<<8|Wire.read(); // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
AcY=Wire.read()<<8|Wire.read(); // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
AcZ=Wire.read()<<8|Wire.read(); // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
Tmp=Wire.read()<<8|Wire.read(); // 0x41 (TEMP_OUT_H) & 0x42 (TEMP_OUT_L)
GyX=Wire.read()<<8|Wire.read(); // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
GyY=Wire.read()<<8|Wire.read(); // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
GyZ=Wire.read()<<8|Wire.read(); // 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
Serial.print("AcX = "); Serial.print(AcX);
Serial.print(" | AcY = "); Serial.print(AcY);
Serial.print(" | AcZ = "); Serial.print(AcZ);
Serial.print(" | Tmp = "); Serial.print(Tmp/340.00+36.53); //equation for temperature in degrees C from datasheet
Serial.print(" | GyX = "); Serial.print(GyX);
Serial.print(" | GyY = "); Serial.print(GyY);
Serial.print(" | GyZ = "); Serial.println(GyZ);
readSensor();
Serial.print("Temperature: ");
Serial.print(temperature,DEC);
Serial.print(" Pressure: ");
Serial.println(pressure,DEC);
delay(333);
