Please reply by message if you want to do any of the following:
- Add audible notifications or alerts to a project?
- Develop a project to to play MP3 and WAV files?
- Reference DFPlayer information?
and you want to get early access to a new library:
The library:
- Masks the complexity of the DFPlayer command-set under methods that mimic the buttons on a portable MP3 player: Play, Stop, Pause, Resume, Mute, Skip, … etc.
- Handles ALL communication with the DFPlayer via a single, light-weight method (state machine) that can be run in loop(), or via a timer.
- Provides instant access to DFPlayer states with methods like isPlaying(), isIdle(), isPaused(), isSleeping(), and isMuted().
- Automatically puts DFPlayer into low-power sleep mode after two seconds of inactivity, and automatically wakes DFPlayer when the next play command is issued.
- Supports SD and USB media.
- Is packaged with four sample applications, and a QuickStart Guide.
- Was built for and tested on Particle devices.
Project Objective: Provide a light-weight, reliable, easy to use, library that will:
- Make it easy to generate audible alarms, notifications, or other sounds within Particle projects.
- Support development of traditional mp3 / wav player applications.
- Provide documentation and resources to assist anyone who seeks information about the DFPlaye
