Add new wifi with iOS app without changing the name of the device
Hi all,
I need to add often new wifi network to my device, and I'd like to do it using the app and without changing the name of the device. I read in the docs that
To add a new network after your initial setup, you'd put your device into Listening Mode
again and proceede as above (the claiming part can be skipped).
What does it mean that the claiming part can be skipped?
The only way I found to set a new network in the device is to tap the + button in the app, and that goes through the whole process of setting up the device, and asks me to put a name for the device.
Is there another way?
