I've adapted one of our designs to use the M404 (US) and M524 (int).
Now using OS vers. 6.2.1.
The sandbox (web page) indicates that the M404 has "247.3kB of 2.8MB of RAM used". So I have been trying to create an ever larger array, just to see if I can get access to all the RAM now available in the MSoM. However, when local compiling with VS Code, I get the following error:
text data bss dec hex filename
1170070 130760 185778 1486608 16af10 ../../../build/target/system-part1/platform-35-m/system-part1.elf
Creating d:/MCU/particle/projects/ch4v6/target/6.2.1/msom/memory_platform_user.ld ...
c:/users/jim/.particle/toolchains/gcc-arm/10.2.1/bin/../lib/gcc/arm-none-eabi/10.2.1/../../../../arm-none-eabi/bin/ld.exe: d:/MCU/particle/projects/ch4v6/target/6.2.1/msom/ch4v6.elf section `.bss' will not fit in region `SRAM'
It appears that the linker doesn't know that there are MBs of RAM available.
Any thoughts on how to access the nearly 3MB of RAM on the MSoM?
