A Question on Subfolders/Directories in Libraries
I am making progress on my own NFC532 library ( https://github.com/reducedhackers/pn532nfcshield )
What I am interested in here is how does the compiler treat the paths for files in the library . For example I can succesfully include the header from the library…
#include "pn532_i2c/pn532_i2c.h"
However inside this header file are includes for other headers in the library and I wondered what the correct format for those paths is; currently I get the usual file or directory not found error; I am using the WebIDE
pn532_i2c/pn532_i2c.h:5:38: fatal error: pn532_i2c/PN532Interface.h: No such file or directory
 #include "pn532_i2c/PN532Interface.h"
That PN532Interface.h file is in the PN532 folder under the firmware folder; its path relative to the pn532_i2c.h file is ./PN532/PN532Interface.h however I have tried variations such as ;
#include "PN532Interface.h"
#include "pn532_i2c/PN532/PN532Interface.h"
Searching down the documentation on this has not proven useful but thats not to say it does not exist; just I have not found it easy to locate an answer for so I thought is I posed it here it might help direct myself and others.
I'm working from this library which I am inhertiing from a working arduino library https://github.com/reducedhackers/pn532nfcshield
As ever thanks to anyone taking their time to read this.
You’d need to put the include statement the way the file containing it sees the included header file.
For imported libraries in Web IDE you’ll get a subdirectory with the library name with all its library files in it.
So in your project .ino and additional .h/.cpp tabs you’d need to write
#include "libName/libName.h"
#include "libName/libExtraFile.h"
but for files that are part of the library they all live on the same level, so there you’d write
// this is libName.h
#include "libExtraFile.h"
And for your samples the same rules apply as for any project .ino
I don’t think you’ll find that in the docs as thisis default C/C++ behaviour.
I’m not sure how your lib will be named in Web IDE - either by the name you indicated in the spark.json or by the repo name - since I usually name the repo and the spark.json the same - saves me thinking ;-).
But if I assume it’s the spark.json name, your includes in readtag.ino it should look like this
#include "pn532_i2c/PN532/PN532.h"
#include "pn532_i2c/NDEF/NfcAdapter.h"
but
in pn532_i2c.cpp you should write
#include "pn532_i2c.h"
since the pn532_i2c.h lives on the same level as pn532_i2c.cpp.
And exemplary for all files deeper down in your lib, looking at PN532.h
// not like this
// #include "pn532_i2c\PN532\PN532Interface.h"
// but
for the same reason - same level means no path allowed.
BTW: Don’t use #include <....> for anything other than system headers. If you are not sure if it’s a system header or not, use #include ".....".
Thanks @scruffr I had tried that as well
In file included from readtag.cpp:1:0:
This looks like an error in pn532_i2c library. Would you like to create an issue on GitHub to let the author know?
CREATE ISSUE
pn532_i2c/pn532_i2c.h:5:28: fatal error: PN532Interface.h: No such file or directory
compilation terminated.
make[1]: *** [../build/target/user/platform-6readtag.o] Error 1
make: *** [user] Error 2
I think what I may do is rebuild the whole repo with the same repo name as the spark json as well; im familiar with C treating libraries flat; my old Kelley/Pohl is still with me even to this day; but the clarity in documentation was sought. Let me kill the repo on git and try again with a repo matching my json name and so forth
If you get stuck I could try to clone your repo and see if I can get it to run.
First off I’d be delighted for some feed back and help if you are offerig @scruffr;
Here is where I have gotten to.
I renamed the gitrepo : https://github.com/reducedhackers/pn532_i2c_particle
I edited the spark.json and the subsequent .ino and .h files accordingly.
I imported the library from github and selected the example code and tried to verify it.
In the first attempt the library complained
This looks like an error in pn532_i2c_particle library. Would you like to create an issue on GitHub to let the author know?
CREATE ISSUE
pn532_i2c_particle/pn532_i2c_particle.h:5:47: fatal error: PN532Interface.h: No such file or directory
So then I tried the following ( because trial and error is as much a learning tool )
CREATE ISSUE
pn532_i2c_particle/pn532_i2c_particle.h:5:47: fatal error: pn532_i2c_particle/PN532Interface.h: No such file or directory
 #include "pn532_i2c_particle/PN532Interface.h"
In both cased the .h file in question PN532Interface is in the folder PN532 which is a subfolder of the ‘firmware’ folder for the project.
I had some play, but couldn’t get the nested folders to work either, but I’ve created a PR on your repo which flattened the structure and also got rid of some other build errors.
I hope this helps.
Thank you for doing that; ive merged back your pull request and will now read through the edits to learn some more.
I guess it may be worth revisiting this with the IDE team at a later date but for now at least we can confirm that two of us have hammered at it for a bit to see what was up.
Thank you for your time.
As mentioned in the blurb for my PR this is a work-in-progress as the IDE team is working on a completely new library feature with better integration with GitHub and “one-face” across Build, Dev and CLI.
It should also line up a bit better with the Arduino structure.
Thanks for the assist here; I do seem to be walking into walls with the environment but its all learning for me It looks like my old Library import/update issue is back again as well Strange BuildIDE behaviour
Congratulations @Scruffr right off the bat and exactly as I have it with the Arduino set up I have that PN532 connected with 2 wires and I can read a card; this means the project keeps moving forward !
Congrats to you, I only moved some things around :wink:
