[5g e-sim] third part connection very unrealiable
Hello team,
Our company is checking out your Tachyon devkit. I'm having trouble getting 5g working with t-mobile esim. Very rarely the connect cmd succeeds, but the connection drops within few minutes again. However, the default esim profile that tachyon provides doesn't have this issue. Is this a known issue? I've attached few error logs if it helps.
This is an urgent project. Looking forward to hearing from you, thanks!
Have you been in touch with T-Mobile?
If it's dropping after x minutes that could indicate a restriction on their end.
