Hi all,
I have two brand new Borons (BRN314) with EtherSIM that are disconnecting/ not connecting to the cloud very often.
Strangely enough, I setup both devices in the same place, time and conditions, and they connected to different carriers. One is running OS 2.2.0 the other 2.3.0. I am using the Cloud debug tool by rickkass. The same behavior occurs with Tinker and a blank app.
Signal strength in both is >60%.
After the activation process, both devices will connect and will end up blinking cyan, sometimes they get online (one for a couple of seconds, the other one for a couple of minutes), both eventually show this error in the log:
0000780074 [comm.protocol] INFO: Checksum has not changed; not sending application DESCRIBE
0000780074 [comm.protocol] INFO: Checksum has not changed; not sending subscriptions
0000781231 [system.nm] INFO: State changed: IP_CONFIGURED → IFACE_UP
0000781232 [net.ppp.client] TRACE: PPP phase → 9
0000781232 [net.ppp.client] TRACE: PPP phase → 6
0000784432 [system] ERROR: sock_send returned -1 118
0000784432 [comm.dtls] ERROR: mbedtls_ssl_write() failed: -0x4e
0000784534 [system] ERROR: sock_send returned -1 118
0000784534 [comm.dtls] ERROR: mbedtls_ssl_read() failed: -0x4e
0000784534 [comm.protocol] ERROR: Event loop error 34
0000784536 [system] WARN: Communication loop error, closing cloud socket
0000784536 [system] INFO: Cloud: disconnecting
0000784538 [system] INFO: Cloud: disconnected
0000785371 [app] INFO: Still trying to connect to the cloud 08:47
INFO: Operator Selection (COPS) Read: mode=automatic (0)
0000072640 [app.help] INFO: format=numeric (2)
0000072642 [app.help] INFO: oper=732123 carrier=Movistar country=Colombia
0000072546 [ncp.at] TRACE: < OK
0000072547 [ncp.at] TRACE: > AT+CGREG?
0000072551 [ncp.at] TRACE: < +CGREG: 2,5,“05AA”,“2C992EE”,6,“32”
0000072649 [app.help] INFO: GPRS network (CGREG) Status: registered, roaming (5)
0000072650 [app.help] INFO: Tracking area code: 05AA
0000072651 [app.help] INFO: Cell identifier: 2C992EE
0000072653 [app.help] INFO: Access technology: GSM + HSDPA & USUPA (6)
I suspect a Simcard issue, any help is greatly appreciated.
