Hello Everyone,
i am trying to figure out how i can level the volts in my particle boron to light 12v LED lights? is there like a leveler or volt adjusters?
Hello Everyone,
@talalgedeon, I believe what you are referring to is a dc-to-dc boost regulator. However, depending on the current requirement for the 12v lights, I would recommend having a separate 12v power supply. You can then use a transistor or relay to control your lights from the Boron. What exactly are you trying to do?
