# 1.3.1-rc.1+ change to Boron solar charging (via VUSB) behavior
**URL:** <https://community.particle.io/t/1-3-1-rc-1-change-to-boron-solar-charging-via-vusb-behavior/51987>\
**Category:** Hardware\
**Tags:** boron\
**Created:** [September 4, 2019, 12:22am UTC](https://community.particle.io/t/1-3-1-rc-1-change-to-boron-solar-charging-via-vusb-behavior/51987 "2019-09-04T00:22:26Z")\
**Showing post:** 8
**Author:** ![epbwhiz](https://sea2.discourse-cdn.com/flex026/user_avatar/community.particle.io/epbwhiz/32/18535_2.png) [@epbwhiz](https://community.particle.io/u/epbwhiz)\
**Post date:** [September 4, 2019, 5:57pm UTC](https://community.particle.io/t/1-3-1-rc-1-change-to-boron-solar-charging-via-vusb-behavior/51987/8 "2019-09-04T17:57:27Z")
Thanks for the quick response fellas! I’m getting a solid charge light, and a climbing charge % !
To make the root cause more difficult to determine 🙂 I shotgunned all suggestions into one code update:
detachInterrupt(LOW_BAT_UC);
delay(2000);
PMIC pmic;
pmic.setInputVoltageLimit(5080);
pmic.setInputCurrentLimit(2000) ;
pmic.setChargeVoltage(4208);
pmic.setChargeCurrent(0,0,1,1,1,0);
pmic.enableDPDM();
pmic.enableBuck();
And like I said, the battery is charging, but the result in the status message is interesting:
```auto
"power":{
  "battery":{
    "charge":93.92
    "state":"discharging"}
"source":"unknown"}
I’ll let somebody else worry about why the state and source is wonky.
Now to figure out which of the 5 things I changed actually made the difference…
Thanks again!
_[View the full topic](https://community.particle.io/t/1-3-1-rc-1-change-to-boron-solar-charging-via-vusb-behavior/51987)._
