Hi @dreamnid,
Looking at the Webhooks documentation, it seems that a custom body request is not supported.
I was actually thinking about something similar in order to make the Particle <> Ubidots integration as seamless as possible and deployed a new endpoint specifically for Particle. Would you like to test it? it works like this:
1- Create a Webhook
Make this HTTP request from a tool like Postman or Hurl.it. Following these tests, we would integrate this request into Ubidots, so you don’t have to use an external tool:
POST https://api.particle.io/v1/webhooks?access_token=YOUR-PARTICLE-TOKEN
Content-Type: application/json
"event": "ubidots",
"url": "http://translate.ubidots.com:9080/particle/?ubi_token=YOUR-UBIDOTS-TOKEN",
"requestType": "POST"
2- Flash your device
This code will send two analog inputs (A0 and A1) to Ubidots, every 10 seconds. In the spark.publish function, specify the event name “ubidots”, and a JSON string in the format {“variable_name”: value, “variable_name”: value, “variable_name”: value, … “variable_name”: value, }.
#define publish_delay 10000
unsigned int lastPublish = 0;
//Serial.begin(9600);
unsigned long now = millis();
int temp = analogRead(A0);
int hum = analogRead(A1);
if ((now - lastPublish) < publish_delay) {
// it hasn't been 10 seconds yet...
return;
Spark.publish("ubidots", "{\"temperature\":" + String(temp) + ", \"humidity\":"+ String(hum) + "}");
lastPublish = now;
Once flashed, you should see the “Spark.publish” events coming in, and the Ubidots webhook replying {“status”:“OK”}
What’s cool about this is you won’t have to create datasources or variables in Ubidots; they will be automatically created using the “core_id” and “variable_name”'s. This is great for provisioning several devices automatically (every device can have the same firmware, but will appear as a different data source inside Ubidots).
Here’s how the data looks inside Ubidots:
Please note that the data source has a tag with the “core_id”; this is how we differentiate each Core, so be careful about not changing it. The data source name can be change without problems:
The variable names should match the ones in your code. If you change them, then a new variable will be created.
