Verifying old code suddenly fails?
Was working on Weasley clock but original 25 LED string wouldn’t work properly with code. Took the system offline for a month while waiting on 50 light string to be delivered. I tried to push the old code to my Photon last night but get an error when verifying stating " error: ‘number_for_key’ was not declared in this scope".
As mentioned, this is the exact same code so I’m unsure why I am suddenly getting this error. What would something have changed on the Particle end in the past month which would effect this?
This is the code I am using.
#include "neopixel/neopixel.h"
#include <stdio.h>
#include <string.h>
#include <math.h>
#define PIXEL_COUNT 50
Adafruit_NeoPixel strip = Adafruit_NeoPixel(PIXEL_COUNT, D3, WS2812B);
int brite = 3;
struct entry {
    String str;
    int n;
struct entry places[] = { //After the first letter and a space, write this word in IFTTT
    "home", 1,
    "work", 2,
    "prison", 3,
    "cottage", 4,
	"mortal", 5,
	"transit", 6,
    0,0
struct entry people[] = { //This letter should be first character in IFTTT
    "C", 1,
    "S", 2,
    "A", 3,
    "R", 4,
	"Y", 5,
	"Z", 6,
    0,0
struct entry colors[] = { //Defines the color for each name.
    "C", 0xffff00,
    "S", 0xff0000,
    "A", 0x00ff00,
    "R", 0x00ff80,
	"Y", 0xff00ff,
	"Z", 0x0000ff,
    0,0
//name=people=capitalized letters
int updateClock(String command) {
  int commaIndex = command.indexOf(' '); //locate the space
  int secondCommaIndex = command.indexOf(' ', commaIndex+1); //locate the second space, starting one character after the first space
  String name = command.substring(0, commaIndex); //name's value is the string starting at the beginning and ending before the space
  String loc = command.substring(commaIndex+1, secondCommaIndex); //loc's value is the string starting after the space and ending before the second space
  int person = number_for_key(name, people); //check for match between the string, name, and people then record the number of the person
  if(person != 0){
	  flashB(number_for_key(name, colors)); //send color code to flash B for name
	  int place = number_for_key(loc, places);
	  if(place != 0){
		  allMineOff(person);
		    int personcolor = number_for_key(name, colors);
		  	int red = floor(personcolor / (256*256));
            int green = (int)floor(personcolor / 256) % 256;
            int blue = personcolor % 256;
		  strip.setPixelColor(7+person+6*place, strip.Color(green, red, blue));
		  strip.show();
  return 1;
    Particle.function("updateClock", updateClock);
    //pinMode(buttonPin, INPUT);
	strip.begin();
    strip.show();
	startupSwirl();
	strip.setBrightness(80);
	allOff();
	for(int j=1; j<=6; j++) { // set everyone to home
	    strip.setPixelColor(7+j+6*4, strip.Color(255, 255, 255));
    strip.show();
    strip.setBrightness(50);
int number_for_key(String key, struct entry dict[]){ //checks the given name with the list of names allowed, returns number of match
    for(int j=0; j<6; j++) {
        String name = dict[j].str;
        if (strcmp(name, key) == 0)
            return dict[j].n;
    return 0;
//This swirl is just for flashiness, only occurs on start up.
void startupSwirl() { // outer hands counterclockwise, inner hands clockwise
	int swirldelay = 50;
	for(int j=0; j<2; j++) {
    	for(int i=14; i<50; i+=3) {
    		allOff();
    		strip.setPixelColor(i, strip.Color(255, 255, 255));
    		strip.setPixelColor(62-i, strip.Color(255, 255, 255));
    		strip.show();
    		delay(swirldelay);
    		allOff();
    		strip.setPixelColor(i+2, strip.Color(255, 255, 255));
    		strip.show();
    		delay(swirldelay);
void flashB(int hexValue){
	int red = floor(hexValue / (256*256));
    int green = (int)floor(hexValue / 256) % 256;
    int blue = hexValue % 256;
	for(int j=0; j<5; j++) {
		for(int i=0; i<14; i++) {
			strip.setPixelColor(i, strip.Color(green, red, blue));
		strip.show();
		delay(300);
			strip.setPixelColor(i, strip.Color(0,0,0));
		strip.show();
		delay(300);
void allMineOff(int n) {
	for(int i=7+n; i<PIXEL_COUNT; i+=6) {
		strip.setPixelColor(i, strip.Color(0, 0, 0));
	strip.show();
void allOff() {
	for(int i=0; i<PIXEL_COUNT; i++) {
	strip.show();
Compiler seems to now struggle with certain function prototypes, particularly those that use structs. So, you can try forward declaring the function (as it should be anyway) at the beginning of the .ino (just after the #include directives).
#include <stdio.h>
#include <string.h>
#include <math.h>
int number_for_key(String key, struct entry dict[]);
// etc ...
Thanks...that seems to have fixed it for me.
