Simple question with an expected disappointing result.
Can I turn on and off the output 5v from the VIN pin using firmware? I’m powering the photon by USB.
I have a couple of servos that are powered by the VIN and it just seems pointless to leave them live in between uses. It would help to stop the servos jittering too.
To stop the jittering you could call Servo.detach()
But the proper way to depower servos would be via a FET. That would even work if you had the servos powered off an external supply and the Photon via Vin.
For your Servo detach suggestion, would this work?
Servo timservo;
Servo louservo;// create servo object to control a servo
// a maximum of eight servo objects can be created
int timpos = 0; // variable to store the servo position for timservo
int loupos = 0; // variable to store the servo position for louservo
//Setup the Servo to the function
Particle.function("timservo", updatetimServo);
//Set pin D0 to be an output
pinMode(D0, OUTPUT);
Particle.function("louservo", updatelouServo);
pinMode(D1, OUTPUT);
Particle.function("bothservo", updatebothServo);
//Take control over the LED on the board
RGB.control(true);
//Turn off the LED - we dont want it flashing behind the photo frame at night
//There may be a better way to do this like turning it off, I found it just as easy to set the colour to nothing
RGB.color(0, 0, 0);
// We don't need to do anything here
//This function is triggered by IFTTT - the 'command' word represents the object used to store the 'position' we send to the function.
//The 'position' we send represents where we want the servo to move to
int updatetimServo(String command)
//Attach the servo to D0
**timservo.attach(D0);**
//Convert string to integer, the code after this requires the 'command' object to be in a number format. IFTTT however passes the object as a 'string' even if it is a 'number'.
uint8_t timpos = command.toInt();
//This tells the servo, attached to D0 to move to the position defined in the 'command' object that was passed when we triggered this function from IFTTT
timservo.write(timpos);
//Flash the LED on so we can see that a message has been recieved - just because we can
RGB.color(255, 0, 0);
//Remember to add the delay for 2 seconds, otherwise the LED will just flash for a period of time too small for us to see
delay(2000);
//Now set the LED back to off
RGB.color(0, 0, 0);
//We return something to signify the end of the function - doesn't really matter what it is
**timservo.detach();**
return 1;
int updatelouServo(String command)
//Attach the servo to D1
**louservo.attach(D1);**
uint8_t loupos = command.toInt();
//This tells the servo, attached to D1 to move to the position defined in the 'command' object that was passed when we triggered this function from IFTTT
delay(5000);
louservo.write(loupos);
RGB.color(0, 0, 255);
delay(2000);
RGB.color(0, 0, 0);
**louservo.detach();**
return 1;
int updatebothServo(String command)
timservo.write(loupos);
delay(2000);
RGB.color(0, 0, 0);
delay(5000);
delay(2000);
RGB.color(0, 0, 0);
return 1;
Generally speaking the idea would be like that, but I would recommend against all these delays in the function handlers.
I’d rather put the control logic into loop() and just set the target target servo and position inside the handler.
And just for good practice, try to return a meaningful value like return timpos;, return loupos; and timpos*1000 + loupos;
And e.g. return -1; on error.
Thanks, I’ll have a go at that! For some reason, with the code as above, I’m still getting servo jitter… actually it’s just a constant whine. Do you know why that could be?
Servo timservo;
RGB.control(true);
RGB.color(0, 0, 0);
timservo.attach(D1);
delay(2000);
RGB.color(0, 0, 0);
//detach the servo
timservo.detach();
return 1;
louservo.attach(D0);
delay(5000);
delay(2000);
RGB.color(0, 0, 0);
//detach the servo
louservo.detach();
return 1;
How close is your servo (and the signal wire) to your Photon/Electron’s antenna? Electronic interference could add to jitter, depending on the type of servo.
How much mass are you moving on the servo? Does removing the load eliminate the chatter?
Thanks! I checked and realised that the screw that was holding the servo was too tight and it was rubbing against the edge, causing the jitter… half a turn and issue sorted. Thanks so much both of you (@ScruffR) for your help!
one last question… if it’s not too much @ScruffR@BulldogLowell - I don’t want to have to take my product apart again if I can avoid it. Is there a way for me to set-up the wifi credentials on the Photon without having to push the SETUP button? Can I set it to listening mode? If so, how would you go about that bearing in mind that I’m relatively useless at the most advanced functions.
