I’ve been working on getting a Beam ( http://www.hoverlabs.co/products/beam ) to work with a particle photon/electron. Getting there. Adapted their demo to display just text. But I’m not sure how and where to use a Particle Function to call the code remotely.
Here’s what I’ve got so far. Any advice appreciated.
Thanks! DC
This started out as an example for Beam. I'm trying to adapt it so that I can remotely trigger text messages.
To that end, I commented out the second part of the demo -- the one with animations.
But I'm not sure how to "call" the right functions with a Particle Function.
Beam is a beautiful LED matrix — features 120 LEDs that displays scrolling text, animations, or custom lighting effects.
Beam can be purchased here: http://www.hoverlabs.co
Written by Emran Mahbub and Jonathan Li for Hover Labs.
BSD license, all text above must be included in any redistribution
# HISTORY
v1.0 - Initial Release
# INSTALLATION
The 4 library files (beam.cpp, beam.h and charactermap.h and frames.h) are required to run Beam.
Run the BeamDemo.ino file.
# SUPPORT
For questions and comments, email us at support@hoverlabs.co
#include "application.h"
#include "beam.h"
/* pin definitions for Beam */
#define RSTPIN 2 //use any digital pin
#define IRQPIN 9 //currently not used
#define BEAMCOUNT 1 //number of beams daisy chained together
/* Iniitialize an instance of Beam */
Beam b = Beam(RSTPIN, IRQPIN, BEAMCOUNT);
/* Timer used by the demo loop */
unsigned long updateTimer = 0;
int demo = 0;
/*I'm thinking that a Particle.function goes here, but not sure. Something like:
Particle.function("scroll",beamScroll);
Wire.begin();
Serial.println("Starting Beam example");
b.begin();
/* b.print("Hello");
b.setSpeed(30);
b.play();*/
The following code originally cycled through two different demos every 20 seconds.
I commented out the second part. Now it just displays the text.
I'm still playing with the functions below, to optimize the display.
But first I'd like to set up a simple Particle Function so that I can trigger a simple text message remotely.
Note that it is not necessary to print to Beam on every loop.
int beamScroll(String command) {
b.begin();
b.print("This is my text.");
b.setSpeed(3);
b.setLoops(3);
b.play(); }
if (millis() - updateTimer > 20000){
// if (demo == 0){
The print() command prints and scrolls text across Beam.
b.begin();
b.setSpeed(3);
b.setLoops(3);
b.play();
//delay(10000);
demo = 1;
updateTimer = millis();
} else if (demo == 1){
//The draw() command draws the frames defined in the frames.h header file,
//and animates them as if flipping through a book.
b.draw();
b.setSpeed(2);
b.setLoops(10);
b.play();
demo = 0;
// do something else here
