@kennethlimcp, this is the error I get when i try to make modules for the branch firmware feature/i2c_timeout
seems to be missing a rule to make target for platform 8?
The particle-cli installation is proving more challenging to implement than I first thought. But that install just freezing isnβt a failure mode Iβve observed. could you run a npm install -g serialport
to see if that works (serialport is a requirement for the particle-cli; normally the particle-cli install process will install the serialport just fine, but thatβs the main area that the installation process can be borked)
I get the same response, it just freezes
Could you try adding a -dd
flag to get any debug output?
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\stevew>npm install -g serialport -dd
npm info it worked if it ends with ok
npm verb cli [ 'C:\\Particle\\Tools\\NodeJS\\\\node.exe',
npm verb cli 'C:\\Particle\\Tools\\NodeJS\\node_modules\\npm\\bin\\npm-cli.js'
npm verb cli 'install',
npm verb cli '-g',
npm verb cli 'serialport',
npm verb cli '-dd' ]
npm info using npm@2.11.3
npm info using node@v0.12.7
npm verb install initial load of \\crystal\FolderRedirections\stevew\Application
Data\npm\package.json
npm verb readDependencies loading dependencies from \\crystal\FolderRedirections
\stevew\Application Data\npm\package.json
npm verb cache add spec serialport
npm verb addNamed "*" is a valid semver range for serialport
npm verb addNameRange registry:https://registry.npmjs.org/serialport not in flig
ht; fetching
npm verb request uri https://registry.npmjs.org/serialport
npm verb request no auth needed
npm info attempt registry request try #1 at 3:57:27 PM
npm verb request id bac0cb1b687111e2
npm verb etag "5WVB7LVONXX6AM90S1Y8XUZPE"
npm http request GET https://registry.npmjs.org/serialport
npm http 304 https://registry.npmjs.org/serialport
npm verb etag https://registry.npmjs.org/serialport from cache
npm verb get saving serialport to \\crystal\FolderRedirections\stevew\Applicatio
n Data\npm-cache\registry.npmjs.org\serialport\.cache.json
npm verb addNamed "1.7.4" is a plain semver version for serialport
npm verb afterAdd \\crystal\FolderRedirections\stevew\Application Data\npm-cache
\serialport\1.7.4\package\package.json not in flight; writing
\serialport\1.7.4\package\package.json written
npm info install serialport@1.7.4 into \\crystal\FolderRedirections\stevew\Appli
cation Data\npm
npm info installOne serialport@1.7.4
npm verb installOne of serialport to \\crystal\FolderRedirections\stevew\Applica
tion Data\npm not in flight; installing
npm verb lock using \\crystal\FolderRedirections\stevew\Application Data\npm-cac
he\_locks\serialport-d76cf28381779e71.lock for \\crystal\FolderRedirections\stev
ew\Application Data\npm\node_modules\serialport
npm verb unbuild node_modules\serialport
npm info preuninstall serialport@1.7.4
npm info uninstall serialport@1.7.4
npm verb unbuild rmStuff serialport@1.7.4 from \\crystal\FolderRedirections\stev
npm verb gentlyRm vacuuming from \\crystal\FolderRedirections\stevew\Application
Data\npm\serialportlist.cmd up to \\crystal\FolderRedirections\stevew\Applicati
on Data\npm
Data\npm\serialportterm.cmd up to \\crystal\FolderRedirections\stevew\Applicati
on Data\npm
Data\npm\serialportlist up to \\crystal\FolderRedirections\stevew\Application D
ata\npm
Data\npm\serialportterm up to \\crystal\FolderRedirections\stevew\Application D
ata\npm
npm info postuninstall serialport@1.7.4
npm verb gentlyRm don't care about contents; nuking \\crystal\FolderRedirections
\stevew\Application Data\npm\node_modules\serialport
npm verb tar unpack \\crystal\FolderRedirections\stevew\Application Data\npm-cac
he\serialport\1.7.4\package.tgz
npm verb tar unpacking to \\crystal\FolderRedirections\stevew\Application Data\n
I have no idea Things to try:
%appdata%/npm/nodemodules
@mumblepins you forgot a statement after βthrow your computer out the window AND send me all your photonsβ
Try following the steps manually here if you want to get it going:
@mumblepins, i think i found a path error thatβs causing issues. The auto installed path for MinGW is βC:\Particle\Toolchain\MinGWβ but I changed it to βC:\Particle\Toolchain\MinGW\binβ and then I was able to install cd modules.
I was looking over the MinGW website http://www.mingw.org/wiki/getting_started in the Environment Settings section and say they included the \bin
You might need to move your path updates to the start of the path? At least for me, other stuff got picked up and broke this until I moved that stuffβs priorityβ¦
Any plans for an Eclipse version? Iβm allergic to NetBeans.
Hi everyone, Iβve been on vacation for the last several weeks, and so havenβt touched this in a bit. Iβm glad that at least some people are having success with this Iβll try to update it over the next few days to make it more robust, and userfriendly. @naikrovek, I havenβt really used Eclipse, but if I get a chance Iβll try to look into it
Donβt worry about it, unless you are looking for a challenge or something.
I got it working a while ago, I can get it again.
Eclipse gives me psychological problems.
I donβt get thatβ¦ I cut my teeth on Eclipse, so it makes lots of sense to me.
I have very little experience with Netbeans or Idea, and accordingly, I hate them both fiercely. They make no sense to me at all.
Anyway, Iβll cater to my own needs. I realize Iβm out of step.
Hi @mumblepins,
I am trying to use the toolchain. My PC has a large PATH, this message shows up running your installer:
PATH not updated, original length 2048 >1024.
Maybe something to look in to?
regards,
Marcus
Hi @mumblepins
I downloaded your installer, thanks very much for it. Here's some feedback:
When I ran the installer, I had all options check. I was a bit surprised to see that the Python 2.7 installer actually deleted my 2.7 installation elsewhere to put it where I told it under the Particle tree. I use Python for other purposes and this can break that. I just thought it would be a separate copy. (I realize it's a python installer issue). Perhaps a comment in the installer saying not to select python if you already have it?
Firing up netbeans and hitting build the toolchain was all marked red and I had to enter it manually. I installed to C:\Programs\Particle
Running the dfu update make command failed. I think it's because of dfu-util failing on the second flash. I've seen elsewhere that this error is "normal." ("Error during download get_status"). Now since the user-part was flashed before the other part, the other part never got executed because of the failure.
The installer hosed my particle-cli and now I cannot set up my Photon. When I invoke "particle setup" I get this output:
C:\Programs\Particle\firmware\main>particle setup
Error loading command C:\Users\sauce\AppData\Roaming\npm\node_modules\particle-cli\commands\CloudCommands.js Error: Cannot find module C:\Users\sosman\AppData\Roaming\npm\node_modules\particle-cli\node_modules\serialport\build\serialport\v1.7.4\Release\node-v14-win32-x64\serialport.node
Error loading command C:\Users\sauce\AppData\Roaming\npm\node_modules\particle-cli\commands\SerialCommand.js Error: Cannot find module C:\Users\sosman\AppData\Roaming\npm\node_modules\particle-cli\node_modules\serialport\build\serialport\v1.7.4\Release\node-v14-win32-x64\serialport.node
_ _ _ _
_ __ __ _ _ | |() | | ___ () ___
| ' \ / _' | '| | |/ | |/ _ \ | |/ _
| |) | (| | | | |_| | (| | /| | () |
| ./ _,|| _|_|_|_|_()|__/
|_| https://particle.io/
Setup is easy! Let's get started...
It appears as though you are already logged in as sauce@xxxx.com
? Would you like to log in with a different account? No
! PROTIP: Hold the MODE/SETUP button on your device until it blinks blue!
! PROTIP: Please make sure you are connected to the internet.
C:\Users\sauce\AppData\Roaming\npm\node_modules\particle-cli\node_modules\inquirer\node_modules\rx\dist\rx.js:579
throw e;
TypeError: Cannot read property 'findDevices' of undefined
at SetupCommand.findDevice (C:\Users\sauce\AppData\Roaming\npm\node_modules\particle-cli\commands\SetupCommand\index.js:294:8)
at accountStatus (C:\Users\sauce\AppData\Roaming\npm\node_modules\particle-cli\commands\SetupCommand\index.js:151:19)
at PromptUI.switchChoice [as completed] (C:\Users\sauce\AppData\Roaming\npm\node_modules\particle-cli\commands\SetupCommand\index.js:118:4)
at PromptUI.onCompletion (C:\Users\sauce\AppData\Roaming\npm\node_modules\particle-cli\node_modules\inquirer\lib\ui\prompt.js:69:10)
at AnonymousObserver.Rx.AnonymousObserver.AnonymousObserver.completed (C:\Users\sauce\AppData\Roaming\npm\node_modules\particle-cli\node_modules
inquirer\node_modules\rx\dist\rx.js:1793:12)
at AnonymousObserver.Rx.internals.AbstractObserver.AbstractObserver.onCompleted (C:\Users\sauce\AppData\Roaming\npm\node_modules\particle-cli\nod
e_modules\inquirer\node_modules\rx\dist\rx.js:1730:14)
at AnonymousObserver.tryCatcher (C:\Users\sauce\AppData\Roaming\npm\node_modules\particle-cli\node_modules\inquirer\node_modules\rx\dist\rx.js:56
7:29)
at AutoDetachObserverPrototype.completed (C:\Users\sauce\AppData\Roaming\npm\node_modules\particle-cli\node_modules\inquirer\node_modules\rx\dist
\rx.js:5288:56)
at AutoDetachObserver.Rx.internals.AbstractObserver.AbstractObserver.onCompleted (C:\Users\sauce\AppData\Roaming\npm\node_modules\particle-cli\no
de_modules\inquirer\node_modules\rx\dist\rx.js:1730:14)
at InnerObserver.onCompleted (C:\Users\sauce\AppData\Roaming\npm\node_modules\particle-cli\node_modules\inquirer\node_modules\rx\dist\rx.js:3425:
65)
Hereβs some more information for the particle-cli error.
C:\Users\sauce\Downloads\particle-cli-master>npm ls
particle-cli@1.6.5 C:\Users\sauce\Downloads\particle-cli-master
βββ UNMET DEPENDENCY chalk@^1.0.0
βββ UNMET DEPENDENCY cli-spinner@^0.2.1
βββ UNMET DEPENDENCY cli-table@^0.3.1
βββ UNMET DEPENDENCY glob@^4.2.1
βββ UNMET DEPENDENCY hogan.js@^2.0.0
βββ UNMET DEPENDENCY inquirer@^0.8.2
βββ UNMET DEPENDENCY lodash@^3.10.1
βββ UNMET DEPENDENCY moment@^2.9.0
βββ UNMET DEPENDENCY node-wifiscanner2@^1.0.0
βββ UNMET DEPENDENCY request@^2.46.0
βββ UNMET DEPENDENCY serialport@^1.5.0
βββ UNMET DEPENDENCY softap-setup@^1.1.4
βββ UNMET DEPENDENCY when@^3.7.2
βββ UNMET DEPENDENCY xtend@^4.0.0
npm ERR! missing: chalk@^1.0.0, required by particle-cli@1.6.5
npm ERR! missing: cli-spinner@^0.2.1, required by particle-cli@1.6.5
npm ERR! missing: cli-table@^0.3.1, required by particle-cli@1.6.5
npm ERR! missing: glob@^4.2.1, required by particle-cli@1.6.5
npm ERR! missing: hogan.js@^2.0.0, required by particle-cli@1.6.5
npm ERR! missing: inquirer@^0.8.2, required by particle-cli@1.6.5
npm ERR! missing: lodash@^3.10.1, required by particle-cli@1.6.5
npm ERR! missing: moment@^2.9.0, required by particle-cli@1.6.5
npm ERR! missing: node-wifiscanner2@^1.0.0, required by particle-cli@1.6.5
npm ERR! missing: request@^2.46.0, required by particle-cli@1.6.5
npm ERR! missing: serialport@^1.5.0, required by particle-cli@1.6.5
npm ERR! missing: softap-setup@^1.1.4, required by particle-cli@1.6.5
npm ERR! missing: when@^3.7.2, required by particle-cli@1.6.5
npm ERR! missing: xtend@^4.0.0, required by particle-cli@1.6.5
You guys don't mind me turning this into my personal blog, do you? Anyway, I manually installed each of the missing dependencies, and still had the same output when I tried "particle setup" as mentioned above.
So I removed particle-cli using npm and reinstalled 1.6.9 which I had manually downloaded from git, and particle-cli now appears to be working again. I was able to re-setup my Photon.
C:\Users\sauce\Downloads\particle-cli-master>npm uninstall -g particle-cli
unbuild particle-cli@1.6.5
C:\Users\sauce\Downloads\particle-cli-master>npm install -g particle-cli
npm WARN engine particle-cli@1.6.9: wanted: {"node":"^0.10.0"} (current: {"node":"0.12.7","npm":"2.11.3"})
> serialport@1.7.4 install C:\Users\sauce\AppData\Roaming\npm\node_modules\particle-cli\node_modules\serialport
> node-pre-gyp install --fallback-to-build
[serialport] Success: "C:\Users\sauce\AppData\Roaming\npm\node_modules\particle-cli\node_modules\serialport\build\serialport\v1.7.4\Release\node-v14-
win32-x64\serialport.node" is installed via remote
C:\Users\sauce\AppData\Roaming\npm\particle -> C:\Users\sauce\AppData\Roaming\npm\node_modules\particle-cli\bin\particle.js
particle-cli@1.6.9 C:\Users\sauce\AppData\Roaming\npm\node_modules\particle-cli
βββ cli-spinner@0.2.1
βββ xtend@4.0.0
βββ node-wifiscanner2@1.0.0
βββ chalk@1.1.1 (escape-string-regexp@1.0.3, supports-color@2.0.0, ansi-styles@2.1.0, has-ansi@2.0.0, strip-ansi@3.0.0)
βββ cli-table@0.3.1 (colors@1.0.3)
βββ when@3.7.3
βββ glob@4.5.3 (inherits@2.0.1, once@1.3.2, inflight@1.0.4, minimatch@2.0.10)
βββ hogan.js@2.0.0
βββ moment@2.10.6
βββ lodash@3.10.1
βββ inquirer@0.8.5 (figures@1.3.5, ansi-regex@1.1.1, cli-width@1.0.1, through@2.3.8, readline2@0.1.1, rx@2.5.3)
βββ softap-setup@1.1.4 (node-rsa@0.2.25, nconf@0.7.2)
βββ request@2.61.0 (aws-sign2@0.5.0, forever-agent@0.6.1, stringstream@0.0.4, tunnel-agent@0.4.1, caseless@0.11.0, oauth-sign@0.8.0, isstream@0.1.2, j
son-stringify-safe@5.0.1, extend@3.0.0, node-uuid@1.4.3, qs@4.0.0, combined-stream@1.0.5, form-data@1.0.0-rc3, mime-types@2.1.5, http-signature@0.11.0
, bl@1.0.0, tough-cookie@2.0.0, har-validator@1.8.0, hawk@3.1.0)
βββ serialport@1.7.4 (bindings@1.2.1, sf@0.1.7, async@0.9.0, nan@1.8.4, debug@2.2.0, optimist@0.6.1)
C:\Users\sauce\Downloads\particle-cli-master>particle
Welcome to the Particle Command line utility!
https://github.com/spark/particle-cli
Usage: particle <command_name> <arguments>
Common Commands:
setup, list, call, get, device, identify, flash, subscribe
compile, monitor, login, logout, help
Less Common Commands:
token, cloud, config, function, keys, serial, udp, update
variable, webhook, wireless
For more information Run: particle help <command_name>
C:\Users\sauce\Downloads\particle-cli-master>particle setup
_ _ _ _
_ __ __ _ _ __| |_(_) ___| | ___ (_) ___
| '_ \ / _` | '__| __| |/ __| |/ _ \ | |/ _ \
| |_) | (_| | | | |_| | (__| | __/_| | (_) |
| .__/ \__,_|_| \__|_|\___|_|\___(_)_|\___/
> It appears as though you are already logged in as sauce@xxx.com
? Would you like to log in with a different account? (y/N)
The reset of the setup proceeded as normal.
So something about the particle-cli installed by the installer was jacked up.
Sauce
I uninstalled and reinstalled the particle CLI and it fixed my issue, which looks the same as yours.
