I can’t seem to find API documentation on “pausing” a SIM subscription for a customer. Is there a way to toggle the monthly subscription on/off?
You should be able to disable the SIM and later reenable it again at any time.
At least this used to be possible.
I need the customer to be able to do that on my web application, so I need to know how to do that using the API. I don’t see any documentation for this.
@doughtz I was looking for this type of use months ago. Particle told me that you need to manage the sim for your customers If nothing has changed from the time I ask. Actually your supposed to manage the sim activation and everything for your customers. At least that what they told me.
Oh boy… how do you scale that if you can’t automate those two things?
I know they told me that they have it in a Todo List
@doughtz ,
Thanks for the question! @ScruffR is correct – if you deactivate the SIM card, it will stop incurring the monthly data plan charge after the current billing period.
The API endpoint to deactivate a SIM is: PUT https://api.particle.io/v1/sims/:iccid
. In the body of the request, pass: {action: "deactivate"}
This will trigger the SIM to be immediately deactivated programmatically. If you would like to reactivate the SIM, use the same endpoint and pass: {action: "reactivate"}
I will also mention that within the next couple weeks, we will be launching SIM Management within a product. This will allow you to associate a fleet of SIMs with your Particle product for simplified billing and batch-actions. If you decide to move your SIM cards to be associated with your product, there will be a different endpoint that you could use to deactivate/reactivate SIM cards.
Does this help?
Jeff
@jeiden Yes, that helps. Is there documentation for this?
Also… unrelated question, is it true the electron has to be turned on in order to pair a customer with a device? Or can I just add the device ID to a customer without the Electron turning on?
