How about allowing the use of Javascript conversion methods like Number()
and Boolean()
in the template and skipping the quotes in the generated JSON if the result is a number or a boolean.
Example:
"eventName": "hm_",
"url": "http://myserver.com/device_events",
"requestType": "POST",
"json": {
"name": "{{PARTICLE_EVENT_NAME}}",
"value": "{{Number(PARTICLE_EVENT_VALUE)}}",
"occured_at": "{{PARTICLE_PUBLISHED_AT}}",
"device_id": "{{PARTICLE_CORE_ID}}"
"mydevices": true
