Just got my new Photon delivered today (very exciting) but I cant for the life of me connect to it in any way. Following the setup guide I plugged it in via USB and held the setup button until it flashed blue (sidenote: I did have to press reset after holding setup for about 20 seconds of nothing changing to get it to flash blue), and that is all it has done since.
I installed the android app but it couldn't find the device it so I went down the CLI route but it was unable to find the Photon via USB and when trying to connect to it via wifi it threw an error:
! Woops. Something went wrong connecting to Photon-8UVQ. Please manually re-connect to your Wi-Fi network.
I tried running cmd and powershell as an administrator but got the same result.
Hi Kenneth, this is connecting to it using the node-js package right? I tried that but at the stage it tries to find devices connected by USB it comes back with a message that no devices were found. Then it tries to scan for wifi devices, finds it but is unable to connect.
I Installed the update using dfu-util (I assume it was successful as it went from flashing yellow to flashing blue light and went from appearing in device manager as a DFU device to a COM4 one) but it still exhibits all the behavior described above
Im trying to flash the user-part.bin file but im not sure it will get anywhere seeing as i cant connect it to the cloud
The driver is already installed and particle-cli is up to date.
When answering no to the first question that just finishes the dialogue after it decides there are no USB devices
Setup is easy! Let's get started...
It appears as though you are already logged in as emailaddress
? Would you like to log in with a different account? No
! PROTIP: Hold the MODE/SETUP button on your device until it blinks blue!
! PROTIP: Please make sure you are connected to the internet.
No devices detected via USB.
? Would you like to scan for nearby Photons in Wi-Fi setup mode? No
Goodbye!
@yardbird you mentioned that you couldn’t get the Android app to see the Photon when it was in listening mode. When in that mode, does the Photon soft AP show up in the list of visible access points on your computer?
Hello, sorry to dig up an old topic, but i have the exact same problem. Following the recommended command, i managed to connect (through putty) the Photon to my wifi, I get the breathing cyan led. That’s good but how do I claim the device in the web interface to be linked with my account ?
It’s a command for the CLI, though I personally prefer particle serial wifi, though you;ll have to claim it manually afterwards, if you choose to go that route.
