[Enter steps to reproduce below:]
Open Atom -> Click USB Icon…
Choose port /dev/ttyACM0…
Select 9600 baud rate
Click Connect
Gives this error
Clicking on “Create issue on the particle-dev package” takes me to this page
Atom Version: 1.10.2
Electron Version: 0.37.8
System: Ubuntu 16.04.1
Thrown From: particle-dev package, v0.1.4
Stack Trace
Uncaught TypeError: openImmediately
is now called autoOpen
and is a property of options
At /home/ilak2k/.atom/packages/particle-dev/node_modules/serialport/lib/serialport.js:79
TypeError: `openImmediately` is now called `autoOpen` and is a property of options
at new SerialPort (/home/ilak2k/.atom/packages/particle-dev/node_modules/serialport/lib/serialport.js:79:11)
at SerialMonitorView.module.exports.SerialMonitorView.connect (/home/ilak2k/.atom/packages/particle-dev/lib/views/serial-monitor-view.coffee:136:17)
at SerialMonitorView.module.exports.SerialMonitorView.toggleConnect (/home/ilak2k/.atom/packages/particle-dev/lib/views/serial-monitor-view.coffee:124:8)
at HTMLButtonElement.<anonymous> (/home/ilak2k/.atom/packages/particle-dev/node_modules/space-pen/lib/space-pen.js:220:36)
at HTMLButtonElement.jQuery.event.dispatch (/home/ilak2k/.atom/packages/particle-dev/node_modules/space-pen/node_modules/jquery/dist/jquery.js:4435:9)
at HTMLButtonElement.elemData.handle (/home/ilak2k/.atom/packages/particle-dev/node_modules/space-pen/node_modules/jquery/dist/jquery.js:4121:28)
Commands
-0:06.6.0 particle-dev:update-menu (atom-workspace.workspace.scrollbars-visible-always.theme-one-dark-syntax.theme-one-dark-ui)
-0:06.6.0 particle-dev:append-menu (atom-workspace.workspace.scrollbars-visible-always.theme-one-dark-syntax.theme-one-dark-ui)
-0:06.4.0 particle-dev:update-menu (atom-workspace.workspace.scrollbars-visible-always.theme-one-dark-syntax.theme-one-dark-ui)
-0:06.4.0 particle-dev:append-menu (atom-workspace.workspace.scrollbars-visible-always.theme-one-dark-syntax.theme-one-dark-ui)
-0:05.5.0 particle-dev:show-serial-monitor (div.package-detail.panels-item)
-0:04.9.0 particle-dev:append-menu (atom-workspace.workspace.scrollbars-visible-always.theme-one-dark-syntax.theme-one-dark-ui)
-0:04.9.0 particle-dev:update-login-status (atom-workspace.workspace.scrollbars-visible-always.theme-one-dark-syntax.theme-one-dark-ui)
-0:04.9.0 particle-dev:update-menu (atom-workspace.workspace.scrollbars-visible-always.theme-one-dark-syntax.theme-one-dark-ui)
2x -0:04.9.0 particle-dev:append-menu (atom-workspace.workspace.scrollbars-visible-always.theme-one-dark-syntax.theme-one-dark-ui)
Config
Installed Packages
# User
console-panel, v0.2.0 (active)
particle-dev, v0.1.4 (active)
particle-dev-cloud-functions, v0.1.0 (active)
particle-dev-cloud-variables, v0.1.0 (active)
particle-dev-complete, v1.0.0 (active)
particle-dev-profiles, v0.1.6 (active)
tool-bar, v1.0.1 (active)
atom-dark-syntax, v0.27.0 (inactive)
atom-dark-ui, v0.52.0 (inactive)
atom-light-syntax, v0.28.0 (inactive)
atom-light-ui, v0.44.0 (inactive)
base16-tomorrow-dark-theme, v1.1.0 (inactive)
base16-tomorrow-light-theme, v1.1.1 (inactive)
one-dark-ui, v1.5.0 (active)
one-light-ui, v1.5.0 (inactive)
one-dark-syntax, v1.3.0 (active)
one-light-syntax, v1.3.0 (inactive)
solarized-dark-syntax, v1.0.2 (inactive)
solarized-light-syntax, v1.0.2 (inactive)
about, v1.5.3 (active)
archive-view, v0.61.1 (active)
autocomplete-atom-api, v0.10.0 (active)
autocomplete-css, v0.11.2 (active)
autocomplete-html, v0.7.2 (active)
autocomplete-plus, v2.31.1 (active)
autocomplete-snippets, v1.11.0 (active)
autoflow, v0.27.0 (inactive)
autosave, v0.23.1 (active)
background-tips, v0.26.1 (active)
bookmarks, v0.41.0 (active)
bracket-matcher, v0.82.1 (active)
command-palette, v0.38.0 (inactive)
deprecation-cop, v0.54.1 (active)
dev-live-reload, v0.47.0 (active)
encoding-selector, v0.22.0 (active)
find-and-replace, v0.201.0 (inactive)
fuzzy-finder, v1.3.0 (active)
git-diff, v1.1.0 (active)
go-to-line, v0.31.0 (inactive)
grammar-selector, v0.48.1 (active)
image-view, v0.58.2 (active)
incompatible-packages, v0.26.1 (active)
keybinding-resolver, v0.35.0 (active)
line-ending-selector, v0.5.0 (active)
link, v0.31.1 (inactive)
markdown-preview, v0.158.0 (active)
notifications, v0.65.0 (active)
open-on-github, v1.2.0 (inactive)
package-generator, v1.0.0 (inactive)
settings-view, v0.242.2 (active)
snippets, v1.0.2 (active)
spell-check, v0.67.1 (active)
status-bar, v1.4.1 (active)
styleguide, v0.47.0 (active)
symbols-view, v0.113.0 (inactive)
tabs, v0.100.2 (active)
timecop, v0.33.2 (active)
tree-view, v0.208.2 (active)
update-package-dependencies, v0.10.0 (active)
welcome, v0.34.0 (active)
whitespace, v0.33.0 (active)
wrap-guide, v0.38.1 (active)
language-c, v0.52.1 (active)
language-clojure, v0.21.0 (active)
language-coffee-script, v0.47.2 (active)
language-csharp, v0.12.1 (active)
language-css, v0.37.1 (active)
language-gfm, v0.88.0 (active)
language-git, v0.15.0 (active)
language-go, v0.42.1 (active)
language-html, v0.45.1 (active)
language-hyperlink, v0.16.0 (active)
language-java, v0.23.0 (active)
language-javascript, v0.119.0 (active)
language-json, v0.18.2 (active)
language-less, v0.29.5 (active)
language-make, v0.22.2 (active)
language-mustache, v0.13.0 (active)
language-objective-c, v0.15.1 (active)
language-perl, v0.35.0 (active)
language-php, v0.37.2 (active)
language-property-list, v0.8.0 (active)
language-python, v0.45.0 (active)
language-ruby, v0.69.0 (active)
language-ruby-on-rails, v0.25.0 (active)
language-sass, v0.56.0 (active)
language-shellscript, v0.22.4 (active)
language-source, v0.9.0 (active)
language-sql, v0.23.0 (active)
language-text, v0.7.1 (active)
language-todo, v0.28.0 (active)
language-toml, v0.18.0 (active)
language-xml, v0.34.9 (active)
language-yaml, v0.26.0 (active)
# Dev
No dev packages
