I’ve created a basic 3D model of the P1 module that can be downloaded from:
The overall envelope are the correct dimensions, but the in-cuts and the placement of the antenna and UF.L connector are not exact yet.
FWIW
FWIW
Hi Wesner,
Could you kindly share with me the STEP file for the P1 module that you’ve posted last year. The link in the post is not valid anymore.
Thanks a lot!
Cheers,
Lucas
Hi Wesner,
Thanks a lot for the link, but the problem is that I have no way to convert the sketch up model to STEP. In case you do have the STEP model, could you share it with me?
Thanks!
Cheers,
Lucas
i found the model, can you send my your email and ill send it to you
just sent, let me know if it looks good
Hi!
Would you mind to send me a copy of the STEP file?
I’ll really appreciatte.
javiher9310@hotmail.com
