Ive been trying to port this myself… but i don’t fully understand how the library is written or how it works.
these are the errors I’m getting now
In file included from ../inc/spark_wiring.h:30:0,
from ../inc/application.h:31,
from /Adafruit_Fingerprint.cpp:17:
../../core-common-lib/SPARK_Firmware_Driver/inc/config.h:12:2: warning: #warning "Defaulting to Release Build" [-Wcpp]
/Adafruit_Fingerprint.cpp:23:44: error: definition of implicitly-declared 'Adafruit_Fingerprint::Adafruit_Fingerprint()'
/Adafruit_Fingerprint.cpp: In member function 'bool Adafruit_Fingerprint::verifyPassword()':
/Adafruit_Fingerprint.cpp:37:54: warning: narrowing conversion of
'(((Adafruit_Fingerprint*)this)->Adafruit_Fingerprint::thePassword
>> 24)' from 'uint32_t {aka long unsigned int}' to 'uint8_t {aka
unsigned char}' inside { } [-Wnarrowing]
>> 16)' from 'uint32_t {aka long unsigned int}' to 'uint8_t {aka
>> 8)' from 'uint32_t {aka long unsigned int}' to 'uint8_t {aka
'((Adafruit_Fingerprint*)this)->Adafruit_Fingerprint::thePassword'
from 'uint32_t {aka long unsigned int}' to 'uint8_t {aka unsigned char}'
/Adafruit_Fingerprint.cpp: In member function 'uint8_t Adafruit_Fingerprint::storeModel(uint16_t)':
/Adafruit_Fingerprint.cpp:87:66: warning: narrowing conversion of
'(((int)id) >> 8)' from 'int' to 'uint8_t {aka unsigned char}'
'(((int)id) & 255)' from 'int' to 'uint8_t {aka unsigned char}'
make: *** [/Adafruit_Fingerprint.o] Error 1
This is the library I’m trying to port https://github.com/adafruit/Adafruit-Fingerprint-Sensor-Library
This is what i have so far
This is an example sketch for our optical Fingerprint sensor
Designed specifically to work with the Adafruit BMP085 Breakout
----> http://www.adafruit.com/products/751
These displays use TTL Serial to communicate, 2 pins are required to
interface
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada for Adafruit Industries.
BSD license, all text above must be included in any redistribution
#include "application.h"
#include "Adafruit_Fingerprint.h"
uint8_t getFingerprintEnroll(uint8_t id);
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino (WHITE wire)
Adafruit_Fingerprint finger();
Serial.println("fingertest");
// set the data rate for the sensor serial port
finger.begin(57600);
if (finger.verifyPassword()) {
Serial.println("Found fingerprint sensor!");
} else {
Serial.println("Did not find fingerprint sensor :(");
while (1);
void loop() // run over and over again
Serial.println("Type in the ID # you want to save this finger as...");
uint8_t id = 0;
while (true) {
while (!Serial.available());
char c = Serial.read();
if (! isdigit(c)) break;
id *= 10;
id += c - '0';
Serial.print("Enrolling ID #");
Serial.println(id);
while (!getFingerprintEnroll(id) );
uint8_t getFingerprintEnroll(uint8_t id) {
uint8_t p = -1;
Serial.println("Waiting for valid finger to enroll");
while (p != FINGERPRINT_OK) {
p = finger.getImage();
switch (p) {
case FINGERPRINT_OK:
Serial.println("Image taken");
break;
case FINGERPRINT_NOFINGER:
Serial.println(".");
break;
case FINGERPRINT_PACKETRECIEVEERR:
Serial.println("Communication error");
break;
case FINGERPRINT_IMAGEFAIL:
Serial.println("Imaging error");
break;
default:
Serial.println("Unknown error");
break;
// OK success!
p = finger.image2Tz(1);
switch (p) {
Serial.println("Image converted");
break;
case FINGERPRINT_IMAGEMESS:
Serial.println("Image too messy");
return p;
return p;
case FINGERPRINT_FEATUREFAIL:
Serial.println("Could not find fingerprint features");
return p;
case FINGERPRINT_INVALIDIMAGE:
return p;
default:
return p;
Serial.println("Remove finger");
delay(2000);
p = 0;
while (p != FINGERPRINT_NOFINGER) {
p = -1;
Serial.println("Place same finger again");
switch (p) {
break;
Serial.print(".");
break;
break;
break;
default:
break;
// OK success!
p = finger.image2Tz(2);
switch (p) {
break;
return p;
return p;
return p;
return p;
default:
return p;
// OK converted!
p = finger.createModel();
if (p == FINGERPRINT_OK) {
Serial.println("Prints matched!");
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
return p;
} else if (p == FINGERPRINT_ENROLLMISMATCH) {
Serial.println("Fingerprints did not match");
return p;
} else {
return p;
p = finger.storeModel(id);
Serial.println("Stored!");
return p;
} else if (p == FINGERPRINT_BADLOCATION) {
Serial.println("Could not store in that location");
return p;
} else if (p == FINGERPRINT_FLASHERR) {
Serial.println("Error writing to flash");
return p;
} else {
return p;
And this is Adafruit_Fingerprint.cpp
This is a library for our optical Fingerprint sensor
interface
Adafruit_Fingerprint::Adafruit_Fingerprint() {
thePassword = 0;
theAddress = 0xFFFFFFFF;
void Adafruit_Fingerprint::begin(uint16_t baudrate) {
Serial1.begin(baudrate);
boolean Adafruit_Fingerprint::verifyPassword(void) {
uint8_t packet[] = {FINGERPRINT_VERIFYPASSWORD,
(thePassword >> 24), (thePassword >> 16),
(thePassword >> 8), thePassword};
writePacket(theAddress, FINGERPRINT_COMMANDPACKET, 7, packet);
uint8_t len = getReply(packet);
if ((len == 1) && (packet[0] == FINGERPRINT_ACKPACKET) && (packet[1] == FINGERPRINT_OK))
return true;
Serial.print("\nGot packet type "); Serial.print(packet[0]);
for (uint8_t i=1; i<len+1;i++) {
Serial.print(" 0x");
Serial.print(packet[i], HEX);
return false;
uint8_t Adafruit_Fingerprint::getImage(void) {
uint8_t packet[] = {FINGERPRINT_GETIMAGE};
writePacket(theAddress, FINGERPRINT_COMMANDPACKET, 3, packet);
if ((len != 1) && (packet[0] != FINGERPRINT_ACKPACKET))
return -1;
return packet[1];
uint8_t Adafruit_Fingerprint::image2Tz(uint8_t slot) {
uint8_t packet[] = {FINGERPRINT_IMAGE2TZ, slot};
writePacket(theAddress, FINGERPRINT_COMMANDPACKET, sizeof(packet)+2, packet);
return -1;
return packet[1];
uint8_t Adafruit_Fingerprint::createModel(void) {
uint8_t packet[] = {FINGERPRINT_REGMODEL};
return -1;
return packet[1];
uint8_t Adafruit_Fingerprint::storeModel(uint16_t id) {
uint8_t packet[] = {FINGERPRINT_STORE, 0x01, id >> 8, id & 0xFF};
return -1;
return packet[1];
uint8_t Adafruit_Fingerprint::emptyDatabase(void) {
uint8_t packet[] = {FINGERPRINT_EMPTY};
return -1;
return packet[1];
uint8_t Adafruit_Fingerprint::fingerFastSearch(void) {
fingerID = 0xFFFF;
confidence = 0xFFFF;
// high speed search of slot #1 starting at page 0x0000 and page #0x00A3
uint8_t packet[] = {FINGERPRINT_HISPEEDSEARCH, 0x01, 0x00, 0x00, 0x00, 0xA3};
return -1;
fingerID = packet[2];
fingerID <<= 8;
fingerID |= packet[3];
confidence = packet[4];
confidence <<= 8;
confidence |= packet[5];
return packet[1];
uint8_t Adafruit_Fingerprint::getTemplateCount(void) {
templateCount = 0xFFFF;
// get number of templates in memory
uint8_t packet[] = {FINGERPRINT_TEMPLATECOUNT};
return -1;
templateCount = packet[2];
templateCount <<= 8;
templateCount |= packet[3];
return packet[1];
void Adafruit_Fingerprint::writePacket(uint32_t addr, uint8_t packettype,
uint16_t len, uint8_t *packet) {
#ifdef FINGERPRINT_DEBUG
Serial.print("---> 0x");
Serial.print((uint8_t)(FINGERPRINT_STARTCODE >> 8), HEX);
Serial.print((uint8_t)FINGERPRINT_STARTCODE, HEX);
Serial.print((uint8_t)(addr >> 24), HEX);
Serial.print((uint8_t)(addr >> 16), HEX);
Serial.print((uint8_t)(addr >> 8), HEX);
Serial.print((uint8_t)(addr), HEX);
Serial.print((uint8_t)packettype, HEX);
Serial.print((uint8_t)(len >> 8), HEX);
Serial.print((uint8_t)(len), HEX);
#endif
Serial1.write((uint8_t)(FINGERPRINT_STARTCODE >> 8));
Serial1.write((uint8_t)FINGERPRINT_STARTCODE);
Serial1.write((uint8_t)(addr >> 24));
Serial1.write((uint8_t)(addr >> 16));
Serial1.write((uint8_t)(addr >> 8));
Serial1.write((uint8_t)(addr));
Serial1.write((uint8_t)packettype);
Serial1.write((uint8_t)(len >> 8));
Serial1.write((uint8_t)(len));
uint16_t sum = (len>>8) + (len&0xFF) + packettype;
for (uint8_t i=0; i< len-2; i++) {
Serial1.write((uint8_t)(packet[i]));
Serial.print(" 0x"); Serial.print(packet[i], HEX);
#endif
sum += packet[i];
//Serial.print("Checksum = 0x"); Serial.println(sum);
Serial.print(" 0x"); Serial.print((uint8_t)(sum>>8), HEX);
Serial.print(" 0x"); Serial.println((uint8_t)(sum), HEX);
#endif
Serial1.write((uint8_t)(sum>>8));
Serial1.write((uint8_t)sum);
uint8_t Adafruit_Fingerprint::getReply(uint8_t packet[], uint16_t timeout) {
uint8_t reply[20], idx;
uint16_t timer=0;
idx = 0;
Serial.print("<--- ");
#endif
while (true) {
while (!Serial1.available()) {
delay(1);
timer++;
if (timer >= timeout) return FINGERPRINT_TIMEOUT;
// something to read!
reply[idx] = Serial1.read();
Serial.print(" 0x"); Serial.print(reply[idx], HEX);
#endif
if ((idx == 0) && (reply[0] != (FINGERPRINT_STARTCODE >> 8)))
continue;
idx++;
// check packet!
if (idx >= 9) {
if ((reply[0] != (FINGERPRINT_STARTCODE >> 8)) ||
(reply[1] != (FINGERPRINT_STARTCODE & 0xFF)))
return FINGERPRINT_BADPACKET;
uint8_t packettype = reply[6];
//Serial.print("Packet type"); Serial.println(packettype);
uint16_t len = reply[7];
len <<= 8;
len |= reply[8];
len -= 2;
//Serial.print("Packet len"); Serial.println(len);
if (idx <= (len+10)) continue;
packet[0] = packettype;
for (uint8_t i=0; i<len; i++) {
packet[1+i] = reply[9+i];
Serial.println();
#endif
return len;
And Adafruit_Fingerprint.h
interface
#define FINGERPRINT_OK 0x00
#define FINGERPRINT_PACKETRECIEVEERR 0x01
#define FINGERPRINT_NOFINGER 0x02
#define FINGERPRINT_IMAGEFAIL 0x03
#define FINGERPRINT_IMAGEMESS 0x06
#define FINGERPRINT_FEATUREFAIL 0x07
#define FINGERPRINT_NOMATCH 0x08
#define FINGERPRINT_NOTFOUND 0x09
#define FINGERPRINT_ENROLLMISMATCH 0x0A
#define FINGERPRINT_BADLOCATION 0x0B
#define FINGERPRINT_DBRANGEFAIL 0x0C
#define FINGERPRINT_UPLOADFEATUREFAIL 0x0D
#define FINGERPRINT_PACKETRESPONSEFAIL 0x0E
#define FINGERPRINT_UPLOADFAIL 0x0F
#define FINGERPRINT_DELETEFAIL 0x10
#define FINGERPRINT_DBCLEARFAIL 0x11
#define FINGERPRINT_PASSFAIL 0x13
#define FINGERPRINT_INVALIDIMAGE 0x15
#define FINGERPRINT_FLASHERR 0x18
#define FINGERPRINT_INVALIDREG 0x1A
#define FINGERPRINT_ADDRCODE 0x20
#define FINGERPRINT_PASSVERIFY 0x21
#define FINGERPRINT_STARTCODE 0xEF01
#define FINGERPRINT_COMMANDPACKET 0x1
#define FINGERPRINT_DATAPACKET 0x2
#define FINGERPRINT_ACKPACKET 0x7
#define FINGERPRINT_ENDDATAPACKET 0x8
#define FINGERPRINT_TIMEOUT 0xFF
#define FINGERPRINT_BADPACKET 0xFE
#define FINGERPRINT_GETIMAGE 0x01
#define FINGERPRINT_IMAGE2TZ 0x02
#define FINGERPRINT_REGMODEL 0x05
#define FINGERPRINT_STORE 0x06
#define FINGERPRINT_EMPTY 0x0D
#define FINGERPRINT_VERIFYPASSWORD 0x13
#define FINGERPRINT_HISPEEDSEARCH 0x1B
#define FINGERPRINT_TEMPLATECOUNT 0x1D
//#define FINGERPRINT_DEBUG
#define DEFAULTTIMEOUT 5000 // milliseconds
class Adafruit_Fingerprint {
public:
void begin(uint16_t baud);
boolean verifyPassword(void);
uint8_t getImage(void);
uint8_t image2Tz(uint8_t slot = 1);
uint8_t createModel(void);
uint8_t emptyDatabase(void);
uint8_t storeModel(uint16_t id);
uint8_t fingerFastSearch(void);
uint8_t getTemplateCount(void);
void writePacket(uint32_t addr, uint8_t packettype, uint16_t len, uint8_t *packet);
uint8_t getReply(uint8_t packet[], uint16_t timeout=DEFAULTTIMEOUT);
uint16_t fingerID, confidence, templateCount;
private:
uint32_t thePassword;
uint32_t theAddress;
