I don’t know if my problem is related or not, so please feel free to break this off into another thread if it isn’t related.
I also have several Digistump Oaks, and two that I have been programming recently are having issues with establishing the link to Particle. When I look at the particle dashboard after programming they, they keep cycling between offline and online for several minutes, and then trigger a spark/status/safe-mode event, at which point the user program starts running properly.
However, if I do a simple blink sketch, and do a SYSTEM_MODE(SEMI_AUTOMATIC) at the top, I don’t have any issues at all. I did try adding a Particle.connect then, and as soon as that line was processed, the offline/online cycle started again. This is on two devices, and is repeatable without fail after several power cycles. However, three other Oaks on the same network which haven’t been modified in a few weeks are still connecting to the cloud fine.
Any ideas or suggestions would be appreciated.
[18:23:35] Event: spark/flash/status - failed (normal for Oak - it was successful)
[18:23:41] Event: spark/status - online
[18:23:51] Event: spark/status - offline
[18:23:52] Event: spark/status - online
[18:24:02] Event: spark/status - offline
[18:24:04] Event: spark/status - online
[18:24:15] Event: spark/status - offline
[18:24:17] Event: spark/status - online
[18:24:27] Event: spark/status - offline
[18:24:28] Event: spark/status - online
[18:24:38] Event: spark/status - offline
[18:24:39] Event: spark/status - online
[18:24:49] Event: spark/status - offline
[18:24:50] Event: spark/status - online
[18:25:00] Event: spark/status - offline
[18:25:02] Event: spark/status - online
[18:25:12] Event: spark/status - offline
[18:25:14] Event: spark/status - online
[18:25:22] Event: spark/status - offline
[18:25:24] Event: spark/status - online
[18:25:34] Event: spark/status - offline
[18:25:35] Event: spark/status - online
[18:25:45] Event: spark/status - offline
[18:25:46] Event: spark/status - online
[18:25:54] Event: spark/status - offline
[18:25:56] Event: spark/status - online
[18:26:05] Event: spark/status - offline
[18:26:07] Event: spark/status - online
[18:26:16] Event: spark/status - offline
[18:26:18] Event: spark/status - online
[18:26:28] Event: spark/status - offline
[18:26:29] Event: spark/status - online
[18:26:38] Event: spark/status - offline
[18:26:41] Event: spark/status - online
[18:26:51] Event: spark/status - offline
[18:26:52] Event: spark/status - online
[18:27:02] Event: spark/status - offline
[18:27:03] Event: spark/status - online
[18:27:12] Event: spark/status - offline
[18:27:14] Event: spark/status - online
[18:27:26] Event: spark/status - offline
[18:27:27] Event: spark/status - online
[18:27:32] Event: spark/status/safe-mode - {"f":[],"v":{},"p":82,"m":[{"s":1040368,"l":"m","vc":30,"vv":30,"f":"s","n":"1","v":6,"d":[]},{"s":1040368,"l":"m","vc":30,"vv":30,"u":"0","f":"u","n":"1","v":1,"d":[{"f":"s","n":"1","v":9,"_":""}]}]}
