Boots up with a brief white LED, blinks green for a while, then cyan for a while, then orange twice, then cyan for a while, then reboots and starts the sequence over.
This Electron may or may not have been used by someone else at some point, I was never able to get it working but I think they might have. They are no longer around so now I need to figure it out. For what it's worth I have 2 devices both displaying identical behavior.
- I have setup an account with the SIM card.
- I have tried updating the keys, for one of the devices it failed saying "Error sending public key to server: Permission Denied" for the other device it succeeded but didn't change anything, still can't connect to the cloud.
- I have updated the firmware.
- I can't 'own' the device since I can't connect it to the cloud
Running tinker with debug outputs gives a bunch of stuff including:
[ Modem::join ] = = = = = = = = = = = = = = = =
76.544 AT send 12 "AT+CGATT=1\r\n"
76.555 AT read OK 6 "\r\nOK\r\n"
76.555 AT send 14 "AT+UPSND=0,8\r\n"
76.565 AT read + 17 "\r\n+UPSND: 0,8,0\r\n"
76.575 AT read OK 6 "\r\nOK\r\n"
76.575 AT send 23 "AT+UPSD=0,7,"0.0.0.0"\r\n"
76.585 AT read OK 6 "\r\nOK\r\n"
76.585 AT send 36 "AT+UPSD=0,1,"spark.telefonica.com"\r\n"
76.595 AT read OK 6 "\r\nOK\r\n"
76.595 AT send 15 "AT+UPSD=0,6,0\r\n"
76.605 AT read OK 6 "\r\nOK\r\n"
76.605 AT send 14 "AT+UPSDA=0,3\r\n"
79.145 AT read OK 6 "\r\nOK\r\n"
79.145 AT send 14 "AT+UPSND=0,0\r\n"
79.155 AT read + 29 "\r\n+UPSND: 0,0,"10.41.4.187"\r\n"
79.165 AT read OK 6 "\r\nOK\r\n"
0000079165:INFO : void establish_cloud_connection() (213) connecting
0000079165:DEBUG: int spark_cloud_socket_connect() (834):sparkSocket Now =-1
0000079165:DEBUG: int spark_cloud_socket_connect() (853):HAL_FLASH_Read_ServerAddress() = type:255,domain:,ip: 0.0.0.0, port: 0
0000079165:WARN : void establish_cloud_connection() (224):Cloud socket connection failed: -1
0000079166:DEBUG: int Internet_Test() (661):Internet test socket
socketSocket(TCP)
79.166 AT send 12 "AT+USOCR=6\r\n"
79.176 AT read + 13 "\r\n+USOCR: 0\r\n"
79.186 AT read OK 6 "\r\nOK\r\n"
Socket 0: handle 0 was created
0000079186:DEBUG: int Internet_Test() (663):socketed testSocket=0
0000079187:DEBUG: int Internet_Test() (685):Connect Attempt
socketConnect(0,port:53)
79.187 AT send 25 "AT+USOCO=0,"8.8.8.8",53\r\n"
79.628 AT read OK 6 "\r\nOK\r\n"
0000079628:DEBUG: int Internet_Test() (687):socket_connect()=success
0000079628:DEBUG: int Internet_Test() (696):Close
socketClose(0)
79.629 AT send 12 "AT+USOCL=0\r\n"
79.899 AT read OK 6 "\r\nOK\r\n"
socketFree(0)
0000082899:INFO : void establish_cloud_connection() (213) connecting
0000082899:DEBUG: int spark_cloud_socket_connect() (834):sparkSocket Now =-1
0000082899:DEBUG: int spark_cloud_socket_connect() (853):HAL_FLASH_Read_ServerAddress() = type:255,domain:,ip: 0.0.0.0, port: 0
0000082900:WARN : void establish_cloud_connection() (224):Cloud socket connection failed: -1
0000082900:ERROR: void handle_cfod() (171):Resetting CC3000 due to 2 failed connect attempts
0000082900:DEBUG: int Internet_Test() (661):Internet test socket
socketSocket(TCP)
82.900 AT send 12 "AT+USOCR=6\r\n"
82.911 AT read + 13 "\r\n+USOCR: 0\r\n"
82.921 AT read OK 6 "\r\nOK\r\n"
0000082921:DEBUG: int Internet_Test() (663):socketed testSocket=0
0000082921:DEBUG: int Internet_Test() (685):Connect Attempt
82.922 AT send 25 "AT+USOCO=0,"8.8.8.8",53\r\n"
84.262 AT read OK 6 "\r\nOK\r\n"
0000084262:DEBUG: int Internet_Test() (687):socket_connect()=success
0000084262:DEBUG: int Internet_Test() (696):Close
socketClose(0)
84.263 AT send 12 "AT+USOCL=0\r\n"
84.534 AT read OK 6 "\r\nOK\r\n"
socketFree(0)
0000084534:WARN : void manage_network_connection() (99):!! Resetting WLAN due to SPARK_WLAN_RESET
